SailNet Community - View Single Post - Volvo MD7a
Thread: Volvo MD7a
post #4 of Old 02-28-2012
klem
Will you have shorepower where you keep it? With it, you can make an engine start much easier through several different methods. The easiest is to aim a heat gun at the air intake for a little while. You could also put an oil pan heater on which helps with cranking speed and does heat the block a little. Another option would be to heat the compartment. With all of these you want to be careful about making it safe. Unfortunately, you can't really hook up a conventional coolant block heater on a raw water cooled engine.
klem is offline
