SailNet Community - View Single Post - whisker pole ??????
post #1 of Old 10-01-2006 Thread Starter
mangomike
Question whisker pole ??????
Hi … I have several questions regarding the use of my newly purchased Forespar 10/18 line control whisker pole. I am a little confused between the information on the Fore spar site and what I've previously observed being done. The First question pertains to the bridal and topping lift. Here is what Fore spar says
The larger Line Control whisker poles come with a center-pole wire "strap" that can be used to rig a bridle for the topping lift. This bridle can be made of a small diameter scrap piece of line. The bridle is attached to the outboard end and the center pole wire strap. By rigging this bridle, the pole is supported in the middle as well as the outboard end. This is a better topping lift support method in heavy air and sea conditions. The reason Forespar® does ….
If You Are Familiar with This Way of Rigging a Pole What Is Your Opinion? Most of the Poles That I've Seen Rigged had the Bridal Running from end to end. Maybe It Doesn't Make Any Difference?
I realize that this is a very subjective question but in light air and fairly flat water I was expecting to be able to use this whisker poll, to pole out my screacher on the same side as the main would be on to give it more surface exposure and hopefully pick up some speed. The below instructions seem to say not to do that. If this can be done, can it be done at as high as 100°, or higher? If you do run a whisker pole on the same side as your main at what degree beyond a beam reach my you start to use.
Forespar ..The pole should be flown level (Thus the need for mast track and cars!) and at the same relative angle to the wind as the main boom. In other words, the whisker pole should be out, opposite the boom at the same angle. As you pull in the mainsail, you would ease out the whisker pole and visa versa. As the pole comes back, the main goes out. Think of the whisker pole as an extension of your boom forward of the mast……… You should not fly a whisker pole on the same side as the main boom. Doing so may jeopardize the pole as your angle of heal may cause the outboard end of the pole to drag in the water.
The last sentence may not apply to our boat because it is a catamaran. Any other help or any articles or reading material you might suggest is more than welcome . Thanks
mangomike is offline
