SailNet Community - View Single Post - Ideas on securing wires inside mast?
post #16 of Old 03-07-2012
casey1999
casey1999's Avatar
Re: Ideas on securing wires inside mast?
Originally Posted by hellosailor View Post
No, a messenger cable is used strictly to move other wires from "this end" to "that end". It isn't used to secure them in place. A messenger cable needs to be at least twice as long as the wire run, so it can go back and forth, and still not be lost at either end. And available to move, without moving any existing wiring that remains in place.
You previous description was for a messenger cable:
Cable Construction Details
The above definition is for a cable puller:
Engineer's Corner -- Installing Communications Cable in Conduit: Pulling Lubricants, Blowing, Tension Calculations, Software, Fiber Optics, Friction Reduction
casey1999 is offline
