SailNet Community - View Single Post - head water intake smell
post #2 of Old 10-04-2006
sailingdog
I flush the head via fresh water before leaving the boat. A lot of it really depends on where you're sailing, since different waters have different critters in them. Have you tried closing the through-hull while still out on the open ocean, to see if the cleaner water out there helps keep the line from stinking as much...might be worth a shot.
BTW, you can generally prime a head by dumping water directly in to the bowl IIRC, but YMMV depending on which head you have.
sailingdog is offline
