SailNet Community - View Single Post - Gelcoat Crack Fix
post #3 of Old 11-06-2001
Gelcoat Crack Fix
Many fine older boats that develop spider type crackling in the Gel Coat affect our pride more than the integrity of the boat. Often the reason is a thick Gel Coat was applied. The best cure remove and replace -Paint or New Gel Coat. You can sand and fill and then paint but more than likely the cracks will show up again. The old Addage a job well done does apply here. Good Luck
timer is offline
