SailNet Community - View Single Post - Resealing/Replacing Beckson Ports?
post #14 of Old 03-09-2012
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Resealing/Replacing Beckson Ports?
What I find to be funny is that MaineSail's pics of the broken 'dogs' from his Beckson ports look an awful lot like to ports on my friends Endeavor 32'.
I'll grant you that the ports in MS's picture and the ones on my friends boat are probably 15 - 30 years old and likely beyond the expected lifespan of a Beckson port. The life expectancy of the NFM port lights has got to be significantly longer then the plastic Becksons.
In my humble opinion the NFM port lights look better, will last longer and will withstand even pretty large waves crashing on them. The Becksons would probably be fine if you are staying close to shore in fair weather and/or your finances are less then robust - but expect to replace them every 10 - 20 years as they do break/crack/leak eventually.
MaineSail will give you great advice.
Good luck.
Everybody has one:
CalebD is offline
