Old 03-10-2012
KIVALO's Avatar
KIVALO KIVALO is online now
KIVALO is on a distinguished road
Re: Ignorant question about cutter rig versus sloop?
That makes sense. Thanks for the response and pdf. I figured there must have been some way to achieve the desired effect.
Brad
s/v KIVALO
Originally Posted by RichH View Post
If the staysl has a cunningham then yes its possible to tension the luff boltrope sleeve to affect good (draft far forward) shape to the staysl and with minimal load on the forestay.
Overtightening the halyard on one of the foresails will cause a loosening in the stay tension of the 'other' headsail.
Its just plain simpler to slacken the forestay when beating so that most of the backstay tension reacts with the headstay.
If you want both headstay forestay combo to be tight, then you really need to apply tension to the running backstays.
For 'almost best' pointing ability with the least hassle with a cutter, remove/stow the forestay, hoist a large LP genoa onto the headstay .... and sail it like a sloop.
http://www.ftp.tognews.com/GoogleFil...f%20Hollow.pdf
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
