SailNet Community - View Single Post - Volvo MD7a
Thread: Volvo MD7a
post #8 of Old 03-12-2012
Rockter
Re: Volvo MD7a
Fit a 235AD...
Electric Fuel Pumps - Stewart Warner
...to pressurise your fuel system and you will never have an air leak again. If the fuel system leaks, you will see the diesel dripping out and you can fix it.
The motor is sound, and oversize pistons were available from Mahle in 1998 and probably still are. Two pistons will cost about 100 each, and a top end gasket set about another 100. Reboring the two barrels would cost about another 100.
You could re-cut and re-grind the valve seats also.
You don't even have to take the motor out of the boat to do it.
Rockter is offline
