BTW, if you've practiced reefing, you can get the time it takes to reef down to a few minutes. Pre-marking the halyards, for the reefing point heights helps you drop the main the right amount without having to raise the main much once you've put the reef in.
Dee Caffari was able to drop the main and make every reef on Aviva in just twenty minutes single handed.
