Re: Center Cockpit Versus Aft Cockpit
We now have our first centercockpit boat and I like everything about it except the look and the fact that you are islolated and it is harder to help with docking when there are only two (or one) onboard. We looked at a number of aft cockpit boats in the 42 -44 foot range (Swan and Hylas among them) and could not accept the compromise they had chosen to get a decent aft cabin - having a very wide bridge deck (in one case it was 5 or 6' feet from the cockpit well. If you wanted a dodger, which is pretty much a given for extended cruising, you had to go out on deck, around the dodger to get to the companionway.
I found handling not an issue. Coming from a 35' it felt the same, just another 10' following along behind.
Big change in our status. we have decided that we cannot safely (in my mind) leave South Africa this season allowing for the time needed for my hand to recover from its injury. All typing is right-handed at this point. We will leave Ainia in SA and head north and west in the early southern summer ~Oct/Nov?
You can check OnAinia.blogspot.com for updates on our travels whenever I get around to it.
