SailNet Community - View Single Post - Lightning ground cable - to where?
post #3 of Old 03-17-2012
kd3pc
kd3pc's Avatar
Re: Lightning ground cable - to where?
chip
you may want to research lightning protection, as much of what mr. honey presents is no longer in vogue, especially the idea of running more cable from the keel back UP to the chain plates...
His comment on static dissipator is dead on. Not so much with ground plates of a square foot or so...you are setting up for a hull breach, should you take a direct hit. The same for using a through hull or anode
Many feel that short of a complete engineered faraday cage, you are better off doing nothing.
Your boat, your call. Best of luck.
kd3pc is online now
