SailNet Community - View Single Post - Largest Semi-Trailerable Sailboat ???
post #62 of Old 03-19-2012
zeta
Re: Largest Semi-Trailerable Sailboat ???
H260 will do most of what you want and you will be able to launch and retrieve at will. The money saved on launching/retrieving can be used to get into a motel every several days to give all a break. I do not believe any trailerable will give you the space you are looking for and all trailer boats will be a compromise. A Nor'Sea 27' will take you around the world, but it will be cramped also w/4. Back to the Hunter 260, it has a pretty good resale value if you decide to move up and you will not even notice it behind your truck. Spending $400/$500 just to get in and out of water will also basically leave you stuck at a location where-as with an easy launcher you can pack up in a few hours and be on the road to a different location at 65mph. Good Luck.
zeta is offline
