SailNet Community - View Single Post - Another "Next Generation" anchor enters the market...
post #18 of Old 03-19-2012
Brent Swain
Re: Another "Next Generation" anchor enters the market...
Test any anchor on dry land before trusting it on your boat. Danforths we made with too wide an angle, flipped on their side and dragged easily, until we reduced the angle. Then it dove in securely. Less than 32 degrees still works , one degree over 32 degrees reduces holding power by 50%. Any more, and it will flip on it's side and drag forever without biting in.
Looks like the anchor shown has the same problem as a Bruce and many others. Get a rock the right size in and it will drag forever. A plow or Delta will let the rock slide out to one side.
I hope to try a roll bar instead of ballast on the next delta I build.
I also hope to make it collapsible. A huge , grossly oversized, collapsible anchor in the bilge can be great insurance in a hurricane. With an alternator , I can easily weld it together when I need it , instead of bolting it.
Brent Swain is offline
