SailNet Community - View Single Post - diesel stop solenoid
post #5 of Old 03-20-2012
erps
the pointy end is the bow
erps's Avatar
Re: diesel stop solenoid
I second Klem's suggestion. I would probably install a manual pull cable as well. If the solenoid holds the fuel open when energized, as John indicated, I would pull off the solenoid and put a spring in there to hold the fuel lever "on" and install a shut off cable to overcome the spring pressure to shut it off.
Agree also with John that diesels should run without power if need be. Cummins motors in highway trucks had a solenoid energized to keep the motor running, but there was a manual override screw in case the solenoid went kaput.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
