SailNet Community - View Single Post - Shore power vs battery while at slip
post #7 of Old 03-21-2012 Thread Starter
sailingcal21
sailingcal21's Avatar
Re: Shore power vs battery while at slip
Originally Posted by DRFerron View Post
Why would you not use shore power if it's available? Curious as to your reasoning.
Biggest reason is to not have a separate lighting system for shore power use. While a guest on some boats, I've seen small florescent and other 110vac type fixtures which lead me to ponder the question.
Thanks for the replies, I was just doing a sanity check to make sure that I wasn't missing anything concerning a battery maintenance issue.
Scott
Scott
s/v Karma
Short Pump, VA
1981 O'Day 34
"No matter where you go, there you are."
sailingcal21 is offline
