SailNet Community - View Single Post - Catalina 27 Motor Mount
post #2 of Old 03-21-2012
MtHopeBay
MtHopeBay's Avatar
Re: Catalina 27 Motor Mount
I can't answer your question directly, but I've been searching around for a similar answer. I have the transom cutout and a Honda 4 stroke 15 HP that I would like to install. I'm currently using a Johnson 9.9 2 stroke that is a tight fit.
Searching here is hit and miss but if you search using Bing or Google you may have better luck. I plan to do more ocean sailing in my 27 and would like to have the 15 HP but I'm considering a small motor just so it's easy to fit the hole and operate. I'd rather have it easy to use than have more horeses and difficult to use.
Good luck.
MikeB
Cal 36 #54
Ida Rose
MtHopeBay is offline
