SailNet Community - View Single Post - Wing on Wing
Thread: Wing on Wing
post #14 of Old 03-22-2012
pdqaltair
pdqaltair's Avatar
Re: Wing on Wing
Amen....
Sailing wing-on-wing sans pole usually works best by sailing slightly by-the-lee.. this tends to direct the AW in a direction that tends to hold the jib out.
Problem is, of course, that you're almost always on the verge of an accidental gybe.. so there's no relaxing on that score.
True...
... Unless you've got a lot of beam.
Sail Delmarva: A Simple Jib Lead Adjustment for Cruising Down Wind
And then it's cake (we rigged an adjustable lead later, though the basic position is the same).
Yes, a preventer is an awfully good idea. For us, the spinnaker sheet works when wing-and-wing. When the chutes is up, we use a separate line to the midships cleat.
Sail Delmarva: The Simplest of Preventers
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
