SailNet Community - View Single Post - Acoustic Insulation for engine room?
post #3 of Old 03-23-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Acoustic Insulation for engine room?
Originally Posted by Flybyknight View Post
Did a study on this subject several years ago, and what I found was the most effective sound deadening composite is lead foil sandwiched between 1 inch (or more) of foam and secured with a pressure sensitive adhesive.
Yes, psa's have sound deadening qualities too.
Hope this helps. Dick
Flyby, Is that lead foil in the middle between TWO layers of foam? Can you make this up yourself in the engine room or does it have to be pre-manufactured sheet goods?
SloopJonB is online now
