SailNet Community - View Single Post - Installing a new winch
post #6 of Old 03-23-2012
Faster
Re: Installing a new winch
A bigger issue adding winches to cabintops after the fact is the likelihood of crushing the balsa core, esp at the 'pressure points' of the bolts and small washers. A backing plate helps spread that out.
Seem this might be a good place to drill out a larger hole (perhaps leaving one skin intact, fill with thickened epoxy and then redrill the holes. This would leave solid material in way of the mounting bolts, eliminating the crush risk, and at the same time thoroughly sealing the core.
Faster is offline
