Old 03-24-2012
downeast450's Avatar
downeast450 downeast450 is offline
Tundra Down
downeast450 is on a distinguished road
Mast wiring access panel
I am doing some work on the base of my mast. I have never opened the wiring access panel before. Ten ss machine screws secure a rectangular aluminum plate in the side of the mast about 6 inches above the base. Since I was doing other work I decided to remove it and clean things up. Ha! Removing it is a bigger chore than I had anticipated.
After removing all the fasteners the only thing left holding it in place was the "sealant" that was used to bed it by the PO. It may be 5200?!! How in the world would I have gained access to the wiring with the mast up if I had needed to? I have "tapped", pried, added solvent and I have the mast lying on its side at waist level! My next effort will be to apply gradual pressure using a C-clamp while warming things with a heat gun. I expect even 5200 will give up. It goes back on with either nothing or butyl caulk. What a PITA it would have been to confront this with the mast up and the wires "in there somewhere" needing attention.
Can you get your mast wiring access panel off?
Down
