SailNet Community - View Single Post - Acoustic Insulation for engine room?
post #12 of Old 03-25-2012
Flybyknight
Re: Acoustic Insulation for engine room?
Flyby, Is that lead foil in the middle between TWO layers of foam? Can you make this up yourself in the engine room or does it have to be pre-manufactured sheet goods?
I purchased the sheet already laminated in a sandwich construction.
It was so long ago ~30 years, that I can't possibly remember the source.
If you were to do the lamination your self, then I would suggest a solvent based psa adhesive (Ashland Chemical Co.), failing that, a water based psa woukd probably work based on the mfgrs recommendation.
I can not over emphasize the need for a PRESSURE SENSITIVE adhesive.
Foil is easily available on line.
Hope thia helps.
Dick
Flybyknight is offline
