SailNet Community - View Single Post - In need for a crash course on Networking
post #3 of Old 03-26-2012
jsaronson
jsaronson's Avatar
Re: In need for a crash course on Networking
The NMEA 2000 cabling has tees and 5 way "splitters" so you can run multiple devices into and out of the interface. The question becomes what data the NSS can use and display. It should display depth, speed and wind if you want it to and if the devices are NMEA compatible. You may be able to replace your transducer with a NMEA compatible model and display the depth on the NSS rather than on the DM, or get an AirMar trducer for speed depth and temp and eliminate a thru-hull and 2 displays.
jsaronson is offline
