SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #331 of Old 03-26-2012
Bill-Rangatira
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Re: Low buck projects- Let's see 'em!
STRF4-3528-W3-12V-WP-T | Electron.com
these have the 3528 smd led's with a lower lumen output 180 -200 /m
power draw is 4.8 w/m
efficiency is 0.024 to 0.026 watts / lumen
STRF5-5050-W3-12V-WP-T | Electron.com
these have the 5050 smd led's with a higher lumen output 200-230 /m
power draw is 7.2 w/m
efficiency is 0.031 to 0.036 watts / lumen
it looks like the 3528 puts more energy into light and thereby less into heat
the biggest issue is regulated 12v supply over voltage may damage the unit
for switching a small latching push button would be easy (push once for on again for off)
for waterproofing circuits I use something called Dragon Skin FX pro 2 part silicone (generally used for casting makeup appliances) non-conductive and works great. Good for ip67 rating if you encapsulate your components and prep your surface
William White
SV Rangatira
1974 Discovery 32
Bill-Rangatira is offline
