SailNet Community - View Single Post - Fuse near the battery
post #5 of Old 03-29-2012 Thread Starter
Re: Fuse near the battery
Thanks for all of the suggestions. This is very helpful.
The smallest I can get is 30 amp, but I think the line from the battery to the panel is 10 AWG, so I think that should be good enough. If I'm reading the reference charts correctly, that line should be able to carry 60 amp safely, so even if there is a short, that fuse should blow before a fire starts.
Do I still need the 20 amp fuse on the panel? That would put two fuses on the same line, which I don't think is necessary. All of the branch wires are at least 14 AWE, so it seems like the 30 amp fuse at the battery should do the trick.
JacobI is offline
