SailNet Community - View Single Post - 5 basic reefing tips, whats yours.
post #8 of Old 04-01-2012 Thread Starter
centaursailor
Senior in age only!!!
centaursailor's Avatar
Re: 5 basic reefing tips, whats yours.
For those who cannot open the link. As to when to use the engine, with strong tides and drying harbours along the coast here the answer is when you have to.
Think of reefing as a balancing act instead of a heavy weather tactic. Sailboats that are balanced tend to sail flatter, faster, steer with less effort (manual, wind-vane, or auto-pilot), and provide more comfort for the sailing crew. Sail your boat balanced and you will maintain good control in all sailing conditions. Watch for these 'time-to-reef' signals to keep your boat sailing balanced with power, speed, and performance:
Whitecaps to Windward?
Do you see whitecaps blowing off the crests of waves to windward? Constant whitecaps tell you that a strong breeze has filled in and will continue for some time. Reef to add power to your boat sails and punch through those waves like a hot knife through butter.
Gusts more Frequent?
How often do those gusts strike the sails and cause the boat to heel? An occasional gust might not be of much concern. But lots of gusts every minute mean you need to reduce sail to keep the boat on her feet.
Helm Hard to Hold?
A balanced helm means being able to steer without strain with one hand. Lots of weather helm and 'white-knuckles' on the wheel or tiller indicates a boat out of harmony with wind and sea. Reef sails to the point that your boat can almost steer herself!
Rail in the Water?
Each time your cruising (or racing) sailboat digs the leeward rail into the water, you lose valuable speed. Extra friction and drag make you slow down. Keep the lee rail clear of the water for faster cruising passages or to beat the competition on race day.
Rounding Up from a Run?
Apparent wind drops when broad reaching or running. And that can lull even the saltiest dog into thinking that the wind has lightened up. Check for whitecaps to windward long before you need to round up. Reef before you round up to keep your boat under positive control.
Use the signals that surround you to warn you that it's time to reef right now. Become the true master and commander of your small cruising sailboat--wherever in the world you choose to cruise!
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
