SailNet Community - View Single Post - Restoring bootstripe by wet sanding?
post #5 of Old 04-05-2012
lancelot9898
Re: Restoring bootstripe by wet sanding?
I've had pretty good luck by just repainting my bootstripe with an Interluk bootstrip paint sold by WM. It does require sanding the surface prior to application as per the instructions on the can. The only wet sanding that I may do is trying to remove some pimples in the freeboard gelkote. Rubbing compound does not seem to work, but someone suggested wet sanding.
lancelot9898 is offline
