SailNet Community - View Single Post - Restoring bootstripe by wet sanding?
post #6 of Old 04-05-2012 Thread Starter
TakeFive
TakeFive's Avatar
Re: Restoring bootstripe by wet sanding?
Originally Posted by lancelot9898 View Post
I've had pretty good luck by just repainting my bootstripe with an Interluk bootstrip paint sold by WM. It does require sanding the surface prior to application as per the instructions on the can. The only wet sanding that I may do is trying to remove some pimples in the freeboard gelkote. Rubbing compound does not seem to work, but someone suggested wet sanding.
This boat is only 13 years old, and the gelcoat is in great shape. I think repainting is overkill at this point. I don't mean to shoot you down - your advice could be very helpful for many readers here with older boats. And if I end up damaging my bootstripe, I'll probably end following your advice.
In the meantime, can someone suggest a proper grit of sandpaper that will give me good productivity without damaging the gelcoat? Or maybe a different compound that will do the trick?
Rick S., Swarthmore, PA
TakeFive is offline
