SailNet Community - View Single Post - Video of Jordan Series Drogue deployment...
post #4 of Old 04-08-2012
Irunbird
Irunbird's Avatar
Re: Video of Jordan Series Drogue deployment...
Originally Posted by Rockter View Post
It looks a good system. How do you anchor it to the deck though? In a storm, the forces will be terrible and I would worry about the forces on the deck fittings. Perhaps it needs dedicated through-hull anchor points and backing plates?
From Jordanseriesdrogue.com -
Attachments on the Hull
The hull attachments for the drogue should be as far outboard and as far aft as possible. I have no information on the ultimate strength of a typical sheet winch installation, and it would be difficult to evaluate each structure. Unfortunately, a winch is not an ideal structure, since the load is applied above the deck line and tends to overturn the winch and pull it out. The optimum attachment for the drogue is clearly a strap similar to a chainplate, bolted to the hull at the corners of the transom and extending aft with a shackle.
For a load of 14,000 lbs, a strap x 2.25 x 18 inches attached with six 3/8 bolts would provide a conservative design.
A large steel cleat would be acceptable if the deck is thick solid fiberglass and a steel plate is provided underneath.
Irunbird is online now
