SailNet Community - View Single Post - Chainplates
Thread: Chainplates
post #25 of Old 04-08-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Chainplates
Originally Posted by overbored View Post
electropolishing is not necessary and does nothing to protect the stainless. mirrior mechanical polishing is the best. any type of polishing, be it mechanical or electropolishing will expose the free iron on the surface and it will rust if exposed to moisture. in addition to the electropolishing process most all parts are passivated and allowed to air dry before returned to the customer. it is the Passivation of the stainless that removes the free iron from the surface and should be done to all stainless parts. Passavation can be done to your parts by soaking in cirtus or nitric acid. soaking in Spotless Stainless will passivate the parts just as well.
I think that the members here are referring to passivation when they say electropolishing. From what my electropolisher told me about the process, passivation is an (the) integral part of the process. The combination of electricity and a nitric acid bath is what gets the iron out to a decent depth.
Also, I beg to differ about it doing nothing - the parts I had done years ago still look the same as the day they were installed. That doesn't happen when they are merely wheel polished and buffed. In that case they start out looking the same but it only lasts a couple of years before they start to lose their gloss and the old brown stains start to make an appearance in corners and on edges and particularly on welds.
SloopJonB is online now
