SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #340 of Old 04-09-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Low buck projects- Let's see 'em!
If you can use a router table or a jigsaw and a drill you can do it yourself, as Faster suggests. I did one for $100. Get a piece of plexi - an offcut will often suffice and is cheaper than having them cut a full sheet.
Dow 795 is the sealant of choice - it's what they use to hold the glass in office towers so it should hold a couple of square feet of plexi.
It's an easy job - cleaning the old sealant off the hatch is the slowest part - the mounting lip must be PERFECTLY clean.
SloopJonB is offline
