SailNet Community - View Single Post - Why does my diesel not rev when in gear?
post #7 of Old 04-09-2012
larrytwo
larrytwo's Avatar
Re: Why does my diesel not rev when in gear?
You might get a compression check. Diesels with lost compression, relying on compression to fire are hard starting when cold and just fine when warmed up. Check your tack idle speed to that recomended in your manual and see if they match. Allso as mentioned by asdf38 you may have a linkage problem. start at the engine/gear connections and work to the control lever, Cheers
B.C. coast videos.
Member, Canadian Coast Guard aux, unit 55. 1980/1998
larrytwo is offline
