SailNet Community - View Single Post - Video of Jordan Series Drogue deployment...
post #41 of Old 04-11-2012
theboilerflue
Re: Video of Jordan Series Drogue deployment...
Steve has a padeye welded to each of his stern bollards from which he uses a chain bridle and the JSD comes off that, the bollards are welded to the hull (below decks) and doubler plated at deck. They have a great blog at *|*
Originally Posted by Irunbird View Post
From Jordanseriesdrogue.com -
Attachments on the Hull
The hull attachments for the drogue should be as far outboard and as far aft as possible. I have no information on the ultimate strength of a typical sheet winch installation, and it would be difficult to evaluate each structure. Unfortunately, a winch is not an ideal structure, since the load is applied above the deck line and tends to overturn the winch and pull it out. The optimum attachment for the drogue is clearly a strap similar to a chainplate, bolted to the hull at the corners of the transom and extending aft with a shackle.
For a load of 14,000 lbs, a strap ¼ x 2.25 x 18 inches attached with six 3/8 bolts would provide a conservative design.
A large steel cleat would be acceptable if the deck is thick solid fiberglass and a steel plate is provided underneath.
theboilerflue is offline
