SailNet Community - View Single Post - hot water heater question
post #2 of Old 10-16-2006
Tropiccafe
Kona
Usually hot water heaters tend to heat up your engine cooling water. Remobing it will let your enging run a little cooler. No engines that I know use the hot water heater heat exchanger to cool the engine. If it is not needed than it would be better to disconnect it.
Tropiccafe is offline
