SailNet Community - View Single Post - Chain Locker Overboard Drain Question
post #1 of Old 04-11-2012 Thread Starter
reka30
A question for those of you who have (or had) chain lockers that drained overboard...
Is the drain just a plain hole (i.e., a thru-hole)?
Or, is there a 1-way valve inside to keep water from coming in through the hole? Or, is there a ball valve inside that would let you close the ability for water to come in the drain?
What is inside the locker?
I get putting the clam shell over the outside to try an prevent some water from coming in.... but, how much does come in when you are off-shore?
Is this an issue? Or, is this just unwarranted concern from someone who has only had anchor lockers that drain into the bilge before?
reka30 is offline
