SailNet Community - View Single Post - Epoxy on the prop?
post #25 of Old 04-14-2012
LakeSuperiorGeezer
LakeSuperiorGeezer's Avatar
Re: Epoxy on the prop?
Tap the prop with a wrinch or small hammer. The prop should ring, if a dull thud, you need another prop. The problem is dezincafication
Do not use a fresh water prop in salt water
The problem with brass instead of bronze
http://www.michel-christen.com/2T-H.pdf
Through hull failures with brass
LakeSuperiorGeezer is offline
