SailNet Community - View Single Post - Prop Removal
Thread: Prop Removal
post #2 of Old 04-16-2012
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Prop Removal
If you are replacing the shaft, then I suggest cutting the shaft to remove the prop. If the shaft is bronze, then a sawzall with a metal cutting blade will do the trick quickly. If it is stainless, then a metal cutting wheel in a circular saw will do it (eventually).
eherlihy is offline
