SailNet Community - View Single Post - Tips For Compound, Polish & Wax
post #152 of Old 04-16-2012
TakeFive
TakeFive's Avatar
Re: Tips For Compound, Polish & Wax
...If your boat is not to badly oxidized Ultra Cutting Creme with a 3M #05713 pad can get you there in just one step plus the wax..! This is my absolute favorite product for compounding / polishing...
Since my boat was in pretty good shape (only 13 years old, maintained OK by previous owners - I mainly needed to remove some stale yellowed wax), I followed this part of MS's advice. The result looks great.
After the one-step port side compound/polish using the Presta, I started a glaze step using Maguire's #9 (since I could not find Presta Chroma locally). However, after doing a small section, it was having absolutely no effect on the appearance, so I stopped after glazing the port side bootstripe. The next day I did the Presta cream on the starboard side, and I was racing against the diminishing shade on that side, so I did not even glaze the bootstripe. If there are invisible swirl marks that will speed up oxidation, I expect that I'll see a difference between the boot stripes on the two sides of the boat. Time will tell.
...Do I apply the wax by hand? Yes!...
In previous years I had used a 6" palm orbital buffer for the Collinite Fleet wax, but this time I found that with the superior surface prep (compound/polish to a high gloss before waxing), the wax buffed out easily by hand with microfiber rag - no need for the electric buffer. It also seemed to take much less wax than it did before, probably due to the reduced surface area.
Also, for boats with only mild oxidation, a big Makita polisher might be overkill. I tried using my 6" orbital buffer to compound/polish the sides of the cabin using Presta Ultra cream, and it easily removed the stale wax and mild oxidation, leaving a surface gloss that was equal in appearance to the hull. For small boats that don't need a 9" pad, and for intricate details that are too small to fit such a large polisher, the smaller buffer seemed to work OK. It's a lot easier on the arms and back, as well. Once again, over time I'll get an idea how this part of the boat holds up vs. the different technique that I used for the hull.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
