SailNet Community - View Single Post - OK, so I'm Sanding My Bottom...
post #9 of Old 04-17-2012
mitiempo
mitiempo's Avatar
Re: OK, so I'm Sanding My Bottom...
Originally Posted by bljones View Post
Squidd,
Ditto what jfdub said.
If you want to be in the water this season, forget you saw what you saw, mix up some slightly thickened epoxy, slather it on the exposed mat, roll it out, mix up some fairing compound, slather it on, sand and shape it, cover it with some barrier coat, bottom paint and go. In the fall, soda blast it and spend the winter cleaning it up.
That's the quick fix.
Brian
mitiempo is offline
