SailNet Community - View Single Post - Not Sure Wich Winch to use
post #8 of Old 04-18-2012
Faster
Re: Not Sure Wich Winch to use
Are you running your sheets direct from the sail to the winch? They are supposed to go to a block that sildes on the track on deck and then UP at at least a 5 deg angle onto the drum. The video still on the post above shows the sheet going down from the drum, into a block, the forward to the trim block and then up to the sail.
Otherwise 'overrides' will never go away.
Faster is offline
