SailNet Community - View Single Post - Not Sure Wich Winch to use
post #30 of Old 04-19-2012
Faster
Re: Not Sure Wich Winch to use
You really do need to get hold of someone with experience willing to go out with you for an hour or two and set you straight on the basics.
It would be well worth the couple of hundred bucks it would cost to hire an instructor for the day to show you the systems. You've got a good boat with very good gear that just needs to be set up correctly. Otherwise I'm afraid someone's going to get hurt first.
Understand this is not a put-down.. you're new and you really need some help - I suspect much of the advice here on this thread is of limited use if only because you don't yet even understand the terminology.
Faster is offline
