SailNet Community - View Single Post - Mainsail comes through again with solar
post #19 of Old 04-20-2012
Bene505
Glad I found Sailnet
Bene505's Avatar
Re: Mainsail comes through again with solar
Bene,
You're really getting beyond the Genasun GV controllers. I would look into a Morningstar or Blue Sky MPPT with temp sensing and a gel setting. Gel's really like temp sensing and proper charging. Genasun can make a GV that will do gel but they are pretty bare bones and designed for smaller arrays, you have "multiple 130's"....
Thanks Maine,
I just bought a "Blue Sky Solar Boost 3024iL MPPT Solar Charge Controller 40A/12V 30A/24V"
Right now I have a 130 watt panel, but I'm looking to get a second one. Since it does 24v, I'm tempted to put the 2 panels in series to cut down on power loss due to wiring. there won't be any shading problems up above the davits.
After buying it, I see it has a dawn to dusk timer. I'll have to check out that feature too.
Regards,
Brad
Bene505 is online now
