SailNet Community - View Single Post - baby stays
Thread: baby stays
post #5 of Old 04-23-2012
saildork
saildork's Avatar
Re: baby stays
Dave, In addition to the advise from Rich on the Sailboat Owners site, you will find many examples of mast-raising solutions for the Catalina 22 on Youtube. Also, I would encourage you to join the C22 National Sailing Association. Lots of good info and very knowledgeable C22 sailors there, eager to help.
That said, I too sail a C22, and I use a homemade gin pole (using an 8' 2X4 with a notch cut into the inboard end to fit against the mast. (I actually added a second, short, 12" section of 2X4, also notched, to the inboard end for strength. I secure it to the mast with a ratcheting tie-down strap.) I then attach the jib halyard to an eyebolt at the top side of the forward end of the 2X4 gin pole, and my boom vang between the stem-fitting at the bow of the boat and another eyebolt at the underside of the gin pole, also at the forward end of the pole. I stand on the cabintop guiding the mast with my right hand while hauling on the vang with my left. I raise the mast high enough to hold it on my shoulder and continue to guide the mast up with my right hand, pausing to haul on the vang. Eventually, the mast gets to a point where I can just push it up with one hand. But I use two!
I continue with the vang until I have all lines fairly taut. At this point, I can move forward and attach the forestay to its fitting. Lowering the rig is this process in reverse.
Some C22 sailors use a system of home-made lateral props from the handrails to a point on the mast 4 - 6 feet above the deck, or other similar system of guy wires to help steady the mast side to side. There are many variations on this theme, all of which work quite well.
When raising the mast, be sure that the shroud, backstay, etc. are not binding or catching on protruding parts of the boat. If you are hauling on the vang and meeting great resistance, you're caught on something. STOP HAULING!!! Find the offending line/hardware, free it, and then proceed.
I'll look for some pictures on my computer, but I'm not sure I have any. Hope this helps.
Sailing isn't a matter of life and death. It's much more important than that!
saildork is offline
