SailNet Community - View Single Post - shoal draft keel vs regular keel
post #2 of Old 04-24-2012
bobperry
grumpy old man
Re: shoal draft keel vs regular keel
Peter:
There is no substitute for draft in terms of performance. Of course I sail on Puget Sound where the water is deep so draft is not an issue here. I'm lucky. I tell clents that draft is a "personal problem". If you can't sail in your chosen cruising ground due to draft then that is not "good performance". Personally I would not want a shoal draft boat.
You might also find that in addition to poor performance on the wind the shoal draft boat will give up some stability.
Bob's Blog ....
bobperry is offline
