SailNet Community - View Single Post - Over Powered in 30 knots?
post #8 of Old 04-24-2012
CarolynShearlock
Re: Over Powered in 30 knots?
Ditto on all the above. And note that if you ever are in a situation where you can't tack and there's an obstruction (such as shallow water coming up), you can do a quick jibe all the way around -- instead of tacking through 90 degrees, you jibe through 270 degrees. Hard to make upwind progress as you'll lose a lot, but it can keep you in safe water.
Carolyn Shearlock
CarolynShearlock is offline
