SailNet Community - View Single Post - Pulling our 31
Thread: Pulling our 31
post #14 of Old 04-24-2012
CS Cruiser
CS Cruiser's Avatar
Dock
Re: Pulling our 31
Originally Posted by eherlihy View Post
Do what you gotta do, and get her back in the water.
The cutlass may be toast if the strut is loose. If it is, you may want to drop the rudder, and check for moisture intrusion while you are at it. I have seen this with other O'days and found water in the rudder on my O'D 35.
Through hulls are relatively easy... Get some G10 from Mc Master-Carr for backing plates, then go here.
Awesome post! thanks as i'm in the process of replacing an old plastic/marelon thru hull and appreciate all the pics and info.
CS Cruiser is offline
