SailNet Community - View Single Post - Survey found corrosion in mast
post #5 of Old 04-25-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Survey found corrosion in mast
Originally Posted by Brewgyver View Post
The surveyor thought the cure might be to cut off the bottom of the mast, and fabricate a step thick enough to make up the difference. Brewgyver
I did that with the keel stepped mast on my boat - took 2" off it and made the new step 2"thicker - it needed a new step anyway so it was no biggy.
Yours is different in that you have those halyard exit boxes right where it will have to be trimmed - they will need to be reinstalled higher as well. Good luck getting the fasteners out of them.
Either get a big discount on the boat to cover all the work or keep looking. Paying pros to do it all will be $$$$$.
SloopJonB is offline
