SailNet Community - View Single Post - sail dimensions, Bene First 345
Old 10-20-2006
maxcontax maxcontax is offline
maxcontax is on a distinguished road
by the numbers
Thanks for your reply, I did the IPEJ numbers and came close to manufacturer's 540 ft2 ( it was 513 ft2) for total sail area.
Presuming a "square function" for pressure on sails, ie 70% sail area results in 1/2 the force (.7 x .7 = .49), the jib I am looking for would be 160 ft2. Maybe the problem is nomenclature: maybe it is not a storm jib, but a working jib.
When I furl the headsail to 70% and double reef the main,the boat pulls well on a reach but does not point nearly as well. My 150 has the foam pad insert to keep sail shape but the 100 does not. In 18 knots with all the laundry out it is lively and fast and points very high, but is right on the edge. for making time in good wind I am looking for a jib SA that I can hank on, furl it it gets wild, but mainly run it full size, and balanced. There are a few passages I make with pretty steady 25-25 knot winds and it would be nice to set up for that. That sets up for double the wind velocity over a 100% sail plan with half the force on the sails. This boat needs the jib to be working to reach in heavier winds.
I do have a 3rd reef point set up but have never used it.
