SailNet Community - View Single Post - Spirit 23 modifications
post #12 of Old 04-27-2012
JUST MESSIN WITH IT
Re: Spirit 23 modifications
I have just ripped out the headlining as it had holes all over the place and scruffy marks. Found lots of the deck hardware bolts were loose and letting water in. After tighenening everything up i sprayed the underside with flex seal.
Just replaced the liner with a nice blue color liner. Had new marine vinyl cushions made in ivory, using some leftover vinyl to trim the edges. Stained the woodwork up a cherry chestnut color and varnished. Customised a 100 dollar bimini to stand just 2 inches under the boom so i can actually stand up when its up. Started to take out the windows to re-seal them, but after the first one was jammed in solid i changed my mind and sealed them in place instead. Installed a 4 speaker digital sound system and a solar panel. Removed all the teak wood from the outside of the boat , rubbed it down stained it and re varnished it. Made new entrance panels.
I have a few more bits to do then ill take pictures.
JUST MESSIN WITH IT is offline
