SailNet Community - View Single Post - How much bottom paint?
post #6 of Old 04-27-2012
LarryandSusanMacDonald
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
Re: How much bottom paint?
I always start with the waterline, then the rudder. Then the rest of the bottom. Then, when it's dry another at the waterline and then another on the rudder. Next day - same thing - so you end up with 4 coats on the waterline and rudder, two on the rest of the bottom. I also put quite a few coats of a gray spray on the prop - I forget what it's called - something like Barnacle Buster - it dries in just a few minutes, so you can pile on a bunch of coats. Has worked well for us. Like the Micron Extra - it's pricey but worth it.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
