SailNet Community - View Single Post - Asymmetric and pulpit
post #7 of Old 04-28-2012 Thread Starter
chris_gee
Re: Asymmetric and pulpit
Yes that was the other possibility I thought of but rejected because you talked of hauling down. Your system adds fullness if it goes higher but does not add to the gap nor allow the possibility of the luff rotating to windward. It is simpler and works ok, not sure if better than simply fixing it at the bottom. Just saying it is better to be able to adjust the tack pendant length, That just requires a block.
chris_gee is offline
